I have got a big problem with my package management (apt).
I tried to install the multiscan:i386 package and since then I always get errors when I'm using commands dealing with the package management.
I don't know if it matters, but I have got an i7-4720HQ, Ubuntu 17.10.1, 64-bit architecture and I'm normally installing amd64 packages.
me@LINUX:~$ sudo apt remove multiscan
[sudo] password for me:
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
multiscan:i386
0 upgraded, 0 newly installed, 1 to remove and 1647 not upgraded.
1 not fully installed or removed.
After this operation, 98.3 kB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 459704 files and directories currently installed.)
Removing multiscan:i386 (0.8.5-1) ...
install-info: No dir file specified; try --help for more information.
dpkg: error processing package multiscan:i386 (--remove):
subprocess installed pre-removal script returned error exit status 1
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit status 1
multiscan:i386
