53
How can I set Hibernation in Ubuntu 18.04 LTS (laptop)?
When I open the Power option > When the Power Button is pressed, I just see the following options:
  • Suspend
  • Power OFF
  • Nothing
But does not show Hibernate.
Melebius
  • 11,750
Rodolfho
  • 643
If you are OK with suspending instead of hibernating, you can try this:
  1. Before you click "Power Button" - press "Alt"
    OR
  2. Click "Power Button" and hold it.
SuRa
  • 363
Ivan
  • 455
20
sudo systemctl hibernate
This did not work for me. I try pm-hibernate which did not work for me either until I added missing package uswsusp
sudo apt install uswsusp
Pa Weł
  • 309
12
Use this, it is more recent. It worked for me with a new 18.04 install on my laptop. http://ubuntuhandbook.org/index.php/2018/05/add-hibernate-option-ubuntu-18-04/
Also, check that you have a swap file before you start. You should have one by default. Run
swapon --show
to check.
