thanks in advance for any help.
My Server:
I just installed a Ubuntu Server 17.04 with basic software and LAMP. (I first tried 18, but because of this bug (https://bugs.launchpad.net/ubuntu/+source/curtin/+bug/1767569) I cannot install it from an usb device.
Goal is to have a local webserver in my current intranet. Apache, PHP and MySQL are all running fine.
I already configured my DNS to point to the webserver and I get the apache default site. When opening my phpinfo I get PHP Version 7.0.15-1ubuntu4, so php7 is running fine.
Haven't tried the ftp yet, but that could be done later.
Problem:
All I need now is to get phpmadmin running, because right now I get an error when opening /phpmyadmin So I checked the server and it seems like phpmyadmin isn't installed together with LAMP (no phpmyadmin folder in /usr/share/)
What I have tried so far:
- I've added
deb http://us.archive.ubuntu.com/ubuntu/ zesty universe multiverseanddeb http://us.archive.ubuntu.com/ubuntu/ zesty-updates universe multiverseto the repo list - I've added the phpmyadmin repository
sudo add-apt-repository ppa:nijel/phpmyadmin - I've
apt-get updateandapt-get upgrademultiple times - Used
apt-get install -f - Many more things I cannot remember right now, but have been reverted afterwards.
Reading package lists... Done
Building dependency tree
phpmyadmin : Depends: php but it is not installable
Depends: php-mbstring but it is not installable
Depends: php-xml but it is not installable
Depends: libjs-sphinxdoc (>= 1.0) but it is not installable
Depends: dbconfig-mysql but it is not installable or
dbconfig-no-thanks but it is not installable or
dbconfig-common (< 2.0.0) but it is not installable
Depends: php-php-gettext but it is not installable or
php-gettext (<= 1:7.0) but it is not installable
Depends: php-phpseclib (>= 2.0) but it is not installable
Recommends: php-curl but it is not installable
Recommends: php-gd but it is not installable
Recommends: php-bz2 but it is not installable
Recommends: php-zip but it is not installable
Recommends: php-tcpdf but it is not installable
Now when I issue the command apt-get install phpmyadmin php php-mbstring php-xml libjs-sphinxdoc dbconfig-mysql php-php-gettext php-phpseclib php-curl php-gd php-bz2 php-zip php-tcpdf I get following errors:
Package php is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package php-mbstring is not available, but is referred to by another package.
Package php-xml is not available, but is referred to by another package.
Package libjs-sphinxdoc is not available, but is referred to by another package.
Package dbconfig-mysql is not available, but is referred to by another package.
Package php-php-gettext is not available, but is referred to by another package.
Package php-phpseclib is not available, but is referred to by another package.
Package php-curl is not available, but is referred to by another package.
Package php-gd is not available, but is referred to by another package.
Package php-bz2 is not available, but is referred to by another package.
Package php-zip is not available, but is referred to by another package.
Package php-tcpdf is not available, but is referred to by another package.
E: Package 'php' has no installation candidate
E: Package 'php-mbstring' has no installation candidate
E: Package 'php-xml' has no installation candidate
E: Package 'libjs-sphinxdoc' has no installation candidate
E: Package 'dbconfig-mysql' has no installation candidate
E: Package 'php-php-gettext' has no installation candidate
E: Package 'php-phpseclib' has no installation candidate
E: Package 'php-curl' has no installation candidate
E: Package 'php-gd' has no installation candidate
E: Package 'php-bz2' has no installation candidate
E: Package 'php-zip' has no installation candidate
E: Package 'php-tcpdf' has no installation candidate
Right now I don't know what else I can to, but asking here. I've seen that a lot of users already had issues with getting phpmyadmin work on a Linux with LAMP, but I seems that all those issues got resolved with solutions I have already tried. I would really appreciate any help here. (If you ask: Apart from the changes in the sources.list I've mentioned above I didn't add any other repos.)
