I am learning to use netplan. When writing a YAML configuration file I need to know which renderer to use, either NetworkManager or networkd.
How do I know if I am running NetworkManager or networkd?
As near as I can tell, there have been 3 approaches to networks in Linux:
1) The oldest uses the /etc/network/interfaces file and ifup/ifdown scripts to manage these interfaces.
2) After that came the network-manager daemon (often written Network-Manager) which has GUI interfaces available.
3) And most recently the systemd-networkd daemon (sometimes abbreviated just 'networkd') which is based on systemd unit files.
To see how your network is being managed, first you must know if you're system is initializing with systemd or the older init as it's first process. (Debian and Ubuntu, for example now use systemd instead of init).
You can check if your system uses systemd with this:
ps -p 1 -o comm= # i.e. -p = process # 1, -o = output column 'comm' or the command name, & the '=' is to not display column name
So if you are NOT running systemd, then clearly you can rule out systemd-networkd.
If you ARE running systemd, then check which network service daemons are running with these two commands:
sudo service systemd-networkd status
sudo service network-manager status # before Ubuntu V21.10
sudo service NetworkManager status # after Ubuntu V21.10!
You'll see either Active: active (running) or Active: inactive (dead) reported for each one.
Note that you can also run these newer commands, but obviously if you don't have systemd, they won't work for you:
systemctl status systemd-networkd
systemctl status network-manager # before Ubuntu V21.10
systemctl status NetworkManager # after Ubuntu V21.10!
But you're not done yet...
Finally, even if one of these two daemons are running, that doesn't mean your network hardware interfaces are being managed by them, as there are exceptions.
First any interfaces defined in /etc/network/interfaces are ignored by the network-manager package. (man 5 NetworkManager)
Next, systemd-networkd will only manage network addresses and routes for any link for which it finds a .network file with an appropriate [Match] section. (man 8 systemd-networkd).
! Ref: Service name change occurred: from network-manager to NetworkManager.
By default, Ubuntu desktop version ships with Network Manager. In most desktop environments, it does a good job. In this case, the netplan file should hand over networking to Network Manager. Typically, the relevant file is /etc/netplan/01-network-manager-all.yaml It reads:
# Let NetworkManager manage all devices on this system
network:
version: 2
renderer: NetworkManager
In Ubuntu server edition, since no desktop environment is installed by default; i.e. Gnome, Unity, Wayland, KDE, etc., Network Manager is not possible and therefore not installed. In versions 17.10 and later, networking is handled by netplan alone. The typical relevant file is /etc/netplan/01-netcfg.yaml It usually reads:
# This file describes the network interfaces available on your system
# For more information, see netplan(5).
network:
version: 2
renderer: networkd
ethernets:
enp0s3:
dhcp4: yes
...where enp0s3 is your relevant interface. This will allow an internet connection by DHCP until a full and further configuration can be effected by editing the yaml file and following with:
sudo netplan apply
Since Feb 2023, Netplan release 0.106, netplan status has been introduced, which pretty prints a lot of information, including the currently used renderer. The output below is taken from a bare Ubuntu 23.04 installation:
$ netplan status
Online state: online
DNS Addresses: 127.0.0.53 (stub)
DNS Search: <redacted>
● 1: lo ethernet UNKNOWN/UP (unmanaged)
MAC Address: 00:00:00:00:00:00
Addresses: 127.0.0.1/8
::1/128
Routes: ::1 metric 256
● 2: enp0s1 ethernet UP (networkd: enp0s1)
MAC Address: <redacted> (<redacted>)
Addresses: 192.168.64.2/24 (dhcp)
fd88:4b93:b031:f03e:80f0:d4ff:fe4f:15d3/64
fe80::80f0:d4ff:fe4f:15d3/64 (link)
DNS Addresses: 192.168.64.1
fe80::6c7e:67ff:fe8c:8364
Routes: default via 192.168.64.1 from 192.168.64.2 metric 100 (dhcp)
192.168.64.0/24 from 192.168.64.2 metric 100 (link)
192.168.64.1 from 192.168.64.2 metric 100 (dhcp, link)
fd88:4b93:b031:f03e::/64 metric 100 (ra)
fe80::/64 metric 256
You can see that the main NIC enp0s1 is being managed by networkd.
After installing the network-manager package and setting the default renderer to NetworkManager, this is the only line that makes a difference in netplan status:
● 2: enp0s1 ethernet UP (unmanaged)
The main NIC enp0s1 is being managed by NetworkManager now.
