12
I have a problem with the GUI network-manager for VPN. When I use it I get an error message:
unable to load VPN network connection editor
If I use the terminal it works. How can I get the network GUI to work?. Any ideas?.
Zanna
  • 72,312
I have just had the same problem which I fixed. I was attempting to add an OpenVPN connection (you haven't stated which type of VPN you're using) but the idea will work. I already had openvpn and network-manager-openvpn installed via apt, but I needed to add network-manager-openvpn-gnome
sudo apt install network-manager-openvpn-gnome
then restarted network manager (this kills networking until it's fully restarted)
sudo service network-manager restart
After this, I could open system settings again, go to networking and add my OpenVPN stuff.
This has been an issue for a couple of years and was answered here: Unable to load VPN connection editor in Ubuntu 14.04 LTS
Cheers
I have the same problem with my Ubuntu running in VMWare fusion. This works for me: Open network settings window, click on "Ifupdown (ens33)". Then you can connect VPN.
On every reboot you would need to redo it.
  • Made sure I had the following packages installed:
sudo apt-get install openvpn network-manager-openvpn network-manager-openvpn-gnome
  • Restart Network Manager:
  • Made sure OpenVPN was running:
sudo service openvpn restart
I noticed the following errors in syslog grep VPN /var/log/syslog, can also check them look for them with systemctl status network-manager:
Failed to request VPN secrets #3: No agents were available for this request.
  • Opened connection with nmcli, solved the issue.
nmcli --ask connection up VPN-CONNECTION-NAME
holmberd
  • 101
