I did an upgrade via terminal yesterday, everything seemed to work fine but then I noticed very heavy CPU usage by gnome-shell. The problem is that the UHD card is not fully recognized, so it uses instead llvmpipe, so no native 3D acceleration :-( This was working great in 17.10
Some outputs which might be useful:
sudo lspci -nnk | grep -i vga -A3
00:02.0 VGA compatible controller [0300]: Intel Corporation UHD Graphics 620 [8086:5917] (rev 07)
    Subsystem: Dell UHD Graphics 620 [1028:07e6]
    Kernel driver in use: i915
    Kernel modules: i915
glxinfo | grep llv Device: llvmpipe (LLVM 6.0, 256 bits) (0xffffffff) OpenGL renderer string: llvmpipe (LLVM 6.0, 256 bits)
Pls let me know if providing more info would help. I am not sure if the driver is missing or if XORG is broken, please help. I am using XORG at the moment, Wayland freezes (it was working in 17.10).
Thanks!
For me helped setting i915.alpha_support=1. Try using instuction below:
  1. Run sudo nano /etc/default/grub (you may use whatever editor instead of nano)
  2. Add i915.alpha_support=1 to the existing line GRUB_CMDLINE_LINUX_DEFAULT= after quiet splash.
  3. Run sudo update-grub
  4. Reboot
P.S. My backgound with this problem:
Initially I had a blackscreen after splash, so I had to add nomodeset (afterwards replaced to i915.modeset=0). Doing this I could boot the desktop, but it was rendered by LLVMpipe (software rendering using CPU capabilities).
Shurov
  • 101
