I booted my laptop with Ubuntu 18.04 (Try Ubuntu without installing method). Then, I ran the following command:
sudo add-apt-repository universe
sudo add-apt-repository multiverse
sudo add-apt-repository ppa:gezakovacs
sudo apt install unetbootin
I am getting the following message:
Reading package lists... Done
Building dependency tree
unetbootin : Depends: gksu but it is not installable or
kdesudo but it is not installable
Recommends: extlinux but it is not going to be installed
Recommends: unetbootin-translations but it is not going to be installed
I googled a bit and found that in cases like this, we should search the package name in https://packages.ubuntu.com and I did, the results are here but I don't see a Bionic name there. Does this mean I can't install Unetbootin in Ubuntu 18.04? If I can, please tell me how to do it?
