I have an HP MFP M225dn multipurpose printer-scanner. In my new install of 18.04, printing works fine, simple scan recognizes the scanner but won't scan ("unable to connect to scanner"). Was working fine with 16.04 and the HP print manager (HPLIP) software. Anyone else seeing this? Should I install the HPLIP drivers etc. from HP? They do not list 18.04 compatibility. Cheers
p.s. Sane detects the scanner:
xxxxxx@daniel-Z370N:~$ sudo sane-find-scanner
  # sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x03f0 [Hewlett-Packard], product=0x2d2a [HP LaserJet Pro MFP M225dn]) at libusb:001:014
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
  # Not checking for parallel port scanners.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
xxxxx@daniel-Z370N:~$ sudo scanimage -L
device `hpaio:/usb/HP_LaserJet_Pro_MFP_M225dn?serial=CNB9HBWD3M' is a Hewlett-Packard HP_LaserJet_Pro_MFP_M225dn all-in-one
