I set up a triple boot system on btrfs, and have arch, xenial, and bionic like so:
  • encrypted btrfs container
  • each has a dedicated btrfs subvol for it's own root
  • shared unencrypted /boot between the three
I've een using this setup for arch and xenial for more than a year and it's been great. Now that I've added bionic, I have slight worries about the naming of the kernel and initrd. For example:
$ ls /boot
initramfs-linux.img           # arch; no problems here
initrd.img-4.13.0-39-generic  # xenial
initrd.img-4.15.0-20-generic  # bionic
vmlinuz-linux                 # arch
vmlinuz-4.13.0-39-generic     # xenial
vmlinuz-4.15.0-20-generic     # bionic
Maybe bionic names will never conflict with xenial, but maybe they will.
I'm wondering if there's a hook or config file somewhere that could set the default name of these files without me having to compile my own. Basically, some way to act like CONFIG_LOCALVERSION or EXTRAVERSION was passed? Or a hook that could intercept the default file names and append something else?
I maintain my own bootloader (rEFInd now), I don't have worries about that aspect (some may foresee concerns syncing up what I'm asking with grub, for example).
As an aside, I'm open to other solutions. I think the general case is "How do I have several distro boot files co-exist in one partition?" I mention this as I just stumbled on this post, which is about setting a subdirectory, not changing the names. Using paths to separate these would work great as well. Maybe that's described in initramfs-tools, but it's not clear to me [yet].
I can't post a comment that gets at the primary answer well enough, so I'm adding this to address the primary response so far:
You can't change the names for Ubuntu kernels because so many programs refers back to the original names.
This is followed by the use of locate to show how many times in the filesystem the kernel version string is used.
I'm writing from Ubuntu xenial booted with the following refind.conf entry:
$ cat /boot/efi/EFI/refind/refind.conf
menuentry "xenial" {
    icon        /EFI/refind/icons/os_ubuntu.png
    volume      4bdcd743-9d09-2f41-9379-e5491e79ae9d
    loader      /vmlinuz-foo
    initrd      /initrd-foo
    options     "root=UUID=xxxx rootflags=compress=lzo,discard,ssd,subvol=xenial nomodeset $vt_handoff add_efi_memmap ro"
To do this, I did:
$ cd /boot
$ sudo mv initrd.img-4.13.0-39-generic initrd-foo
$ sudo mv vmlinuz-4.13.0-39-generic vmlinuz-foo
The filename itself doesn't matter, as the kernel version is in the kernel:
$ uname -a
Linux roboxenial 4.13.0-39-generic #44~16.04.1-Ubuntu SMP Thu Apr 5 16:43:10 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
So... I can run from any filename I want. The questions still remains if there is a way to have every kernel name changed in some way during installation/upgrade (like a hook). This could be a convention (e.g. initrd-xenial), suffix (initrd.img-4.13.0-39-generic_xenial) or otherwise.
Hendy
  • 256
You can't change the names for Ubuntu kernels because so many programs refers back to the original names. Take for example my current kernel 4.14.34:
$ locate 4.14.34 | wc -l
70192
$ ll /boot/*4.14.34*
-rw-r--r-- 1 root root  1496011 Apr 12 05:53 /boot/abi-4.14.34-041434-generic
-rw-r--r-- 1 root root   213406 Apr 12 05:53 /boot/config-4.14.34-041434-generic
-rw-r--r-- 1 root root 58514444 Apr 28 13:36 /boot/initrd.img-4.14.34-041434-generic
-rw-r--r-- 1 root root        0 Apr 12 05:53 /boot/retpoline-4.14.34-041434-generic
-rw------- 1 root root  3952348 Apr 12 05:53 /boot/System.map-4.14.34-041434-generic
-rw------- 1 root root  8607504 Apr 30 03:52 /boot/vmlinuz-4.14.34-041434-generic
There are 70,192 files link to kernel version 4.14.34 but only five of them reside in /boot where you wish to do your renaming.
As mentioned in comments there is little danger of ArchLinux using the same kernel name as Ubuntu because they have their own unique numbering system: How do I map Linux Kernels to Ubuntu Kernels?
NOTE: At the time this was run I had two Ubuntu 16.04 partitions mounted so the 4.14.34 file count is 35,096 for a single 16.04 installation. Also note headers are included which I believe are optional but which I always install "just in case".
Large listing
Below is the beginning of the locate listing. If vmlinuz were to be renamed the module files would likely not be locatable:
$ locate 4.14.34 | head -n1000
/lib/modprobe.d/blacklist_linux_4.14.34-041434-generic.conf
/lib/modules/4.14.34-041434-generic
/lib/modules/4.14.34-041434-generic/build
/lib/modules/4.14.34-041434-generic/initrd
/lib/modules/4.14.34-041434-generic/kernel
/lib/modules/4.14.34-041434-generic/modules.alias
/lib/modules/4.14.34-041434-generic/modules.alias.bin
/lib/modules/4.14.34-041434-generic/modules.builtin
/lib/modules/4.14.34-041434-generic/modules.builtin.bin
/lib/modules/4.14.34-041434-generic/modules.dep
/lib/modules/4.14.34-041434-generic/modules.dep.bin
/lib/modules/4.14.34-041434-generic/modules.devname
/lib/modules/4.14.34-041434-generic/modules.order
/lib/modules/4.14.34-041434-generic/modules.softdep
/lib/modules/4.14.34-041434-generic/modules.symbols
/lib/modules/4.14.34-041434-generic/modules.symbols.bin
/lib/modules/4.14.34-041434-generic/vdso
/lib/modules/4.14.34-041434-generic/kernel/arch
/lib/modules/4.14.34-041434-generic/kernel/block
/lib/modules/4.14.34-041434-generic/kernel/crypto
/lib/modules/4.14.34-041434-generic/kernel/drivers
/lib/modules/4.14.34-041434-generic/kernel/fs
/lib/modules/4.14.34-041434-generic/kernel/kernel
/lib/modules/4.14.34-041434-generic/kernel/lib
/lib/modules/4.14.34-041434-generic/kernel/mm
/lib/modules/4.14.34-041434-generic/kernel/net
/lib/modules/4.14.34-041434-generic/kernel/sound
/lib/modules/4.14.34-041434-generic/kernel/virt
/lib/modules/4.14.34-041434-generic/kernel/arch/x86
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/events
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kernel
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kvm
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/oprofile
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/platform
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/aes-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/aesni-intel.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/blowfish-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/camellia-aesni-avx-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/camellia-aesni-avx2.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/camellia-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/cast5-avx-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/cast6-avx-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/chacha20-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/crc32-pclmul.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/crct10dif-pclmul.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/des3_ede-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/ghash-clmulni-intel.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/glue_helper.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/poly1305-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/salsa20-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/serpent-avx-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/serpent-avx2.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/serpent-sse2-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/sha1-mb
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/sha1-ssse3.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/sha256-mb
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/sha256-ssse3.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/sha512-mb
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/sha512-ssse3.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/twofish-avx-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/twofish-x86_64-3way.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/twofish-x86_64.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/sha1-mb/sha1-mb.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/sha256-mb/sha256-mb.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/crypto/sha512-mb/sha512-mb.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/events/intel
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/events/intel/intel-cstate.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/events/intel/intel-rapl-perf.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kernel/cpu
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kernel/cpuid.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kernel/msr.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kernel/cpu/mcheck
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kernel/cpu/mcheck/mce-inject.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kvm/kvm-amd.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kvm/kvm-intel.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/kvm/kvm.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/oprofile/oprofile.ko
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/platform/atom
/lib/modules/4.14.34-041434-generic/kernel/arch/x86/platform/atom/punit_atom_debug.ko
/lib/modules/4.14.34-041434-generic/kernel/block/bfq.ko
/lib/modules/4.14.34-041434-generic/kernel/block/kyber-iosched.ko
/lib/modules/4.14.34-041434-generic/kernel/block/mq-deadline.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/842.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/ablk_helper.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/aes_ti.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/af_alg.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/algif_aead.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/algif_hash.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/algif_rng.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/algif_skcipher.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/ansi_cprng.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/anubis.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/arc4.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/asymmetric_keys
/lib/modules/4.14.34-041434-generic/kernel/crypto/async_tx
/lib/modules/4.14.34-041434-generic/kernel/crypto/authenc.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/authencesn.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/blowfish_common.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/blowfish_generic.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/camellia_generic.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/cast5_generic.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/cast6_generic.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/cast_common.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/ccm.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/chacha20_generic.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/chacha20poly1305.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/cmac.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/crc32_generic.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/cryptd.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/crypto_engine.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/crypto_simd.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/crypto_user.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/deflate.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/des_generic.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/ecdh_generic.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/echainiv.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/fcrypt.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/keywrap.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/khazad.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/lrw.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/lz4.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/lz4hc.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/mcryptd.ko
/lib/modules/4.14.34-041434-generic/kernel/crypto/md4.ko
