27
On Ubuntu 14.04 I'm using dnsmasq to resolve wildcard example.com domains to the local machine (desktop computer at home).
After much reading around I cannot for the life of me sort out the same on a clean install of 18.04.
All I want to achieve at the moment is:
  • for ping example.com to ping 127.0.0.1 and not 93.184.216.34;
  • for ping anysubdomain.example.com to also ping 127.0.0.1;
  • and for ping google.com to ping the real google.com via the router/IP DNS.
Surely this must be simple, even trivial?
But I'm stumped. I can get the example.com's resolving but only at the expense of breaking everything else.
How can I do this?
pim
  • 3,350
Nick Rice
  • 331
5 Answers5
59
Here are the steps for ubuntu since 18.04. It's a little bit long since systemd-resolved does not play very well with NetworkManager when configured with dnsmasq.
Yet I still recommend starting dnsmasq from NetworkManager, because network connectivity changes (WIFI, wired, ...) will be handled transparently.
Enable dnsmasq in NetworkManager
Edit the file /etc/NetworkManager/NetworkManager.conf, and add the line dns=dnsmasq to the [main] section, it will look like this :
[main]
plugins=ifupdown,keyfile
dns=dnsmasq
[ifupdown] managed=false
[device] wifi.scan-rand-mac-address=no
Let NetworkManager manage /etc/resolv.conf
sudo rm /etc/resolv.conf ; sudo ln -s /var/run/NetworkManager/resolv.conf /etc/resolv.conf
Configure example.com
echo 'address=/.example.com/127.0.0.1' | sudo tee /etc/NetworkManager/dnsmasq.d/example.com-wildcard.conf
Reload NetworkManager and testing
NetworkManager should be reloaded for the changes to take effect.
sudo systemctl reload NetworkManager
Then we can verify that we can reach some usual site :
dig askubuntu.com +short
151.101.129.69
151.101.65.69
151.101.1.69
151.101.193.69
And lastly verify that the example.com and subdomains are resolved as 127.0.0.1:
dig example.com askubuntu.example.com a.b.c.d.example.com +short
127.0.0.1
127.0.0.1
127.0.0.1
pim
  • 3,350
First make sure in /etc/NetworkManager/NetworkManager.conf the following line is not present or commented out:
dns=dnsmasq
Restart NetworkManager:
sudo systemctl restart NetworkManager
Make sure the NetworkManager-controlled dnsmasq is not running anymore, either by killing the process or rebooting your system.
Then install dnsmasq:
sudo apt install dnsmasq
Add the following to /etc/dnsmasq.d/example.com:
address=/example.com/127.0.0.1
Restart dnsmasq:
sudo systemctl restart dnsmasq
Now you should have a wildcard dns override for example.com.
Based on pim's answer, I have created a gist containing a simple Bash script which uses DNSMasq in combination with NetworkManager to setup the .test domain pointing to 127.0.0.1
See the gist at https://gist.github.com/archan937/d35deef3b1f2b5522dd4b8f397038d27.
You can execute the script with the following command:
curl -sL https://gist.githubusercontent.com/archan937/d35deef3b1f2b5522dd4b8f397038d27/raw/setup-dnsmasq.sh | sudo bash
Cheers!
Paul Engel
This won't be as simple as editing the hosts file. You have a couple of options:
This python DNS proxy that will handle wildcards in /etc/hosts
Using DNSmasq
It is possible to use dnsmasq-base that is already pre-installed in Ubuntu instead of dnsmasq for the same purpose.
So don't install dnsmasq but do all steps from here https://askubuntu.com/a/1031896/211368
If you install dnsmasq it will collide with already running dnsmasq-base and you'll get an error:
failed to create listening socket for port 53: Address already in use
