13
I've had some weird internet issues since upgrading.
First of all, my wifi USB dongle stopped working so I thought it was broken, I replaced it and was getting speeds of under 1 Mbps.
Since then I have had very poor download speeds, and surfing has been a bit hit and miss with some sites loading instantly, and others crawling. everything was fine using the same hardware on 16.04
What can I do to speed things up?
Thanks!
Zanna
  • 72,312
Syteanric
  • 131
I just fixed this on ubuntu 18.04 - turns out there is some kind of issue with 802.11n and iwlwifi Intel chips. The solution is to turn it off.
Check if it works first with:
sudo modprobe -r iwlwifi
sudo modprobe iwlwifi 11n_disable=1
Make it permanent with this command:
echo "options iwlwifi 11n_disable=1" | sudo tee /etc/modprobe.d/iwlwifi.conf
I did this and my wifi speeds instantly went back to normal.
That's for sure 8-) ! With a Advanced-N 6200 in a computer I just picked up, I was getting freezes (no LEDs so I don't know if the kernel paniced..) within a minute or two once I started rsync'ing some files over. 11n_disable=1 solved this for me.
Update: Actually I had freezes with 11n_disable=1 also; I popped my case open and found the card was not fully seated!
hwertz
  • 376
