21
How can I enable/disable GNOME extensions from command line?
I made a animated gif of what I'm trying to do from the terminal to explain it better. I'm not trying to enable or disable just one extension.
I looked at gnome-tweaks -h but it doesn't have the option I'm looking for.
Options:
  --version             show program's version number and exit
  -h, --help            show this help message and exit
  -t, --test            Enable test and debug code
  -l, --load            Load all tweaks
  -p [/, /usr], --prefix=[/, /usr]
                        Installation prefix (for gsettings schema, themes,
                        etc)
  -v, --verbose         Print the names of settings modified
  -d, --debug           Enable debug output
pomsky
  • 70,557
Rick T
  • 2,303
Run
gsettings set org.gnome.shell disable-user-extensions true
to disable all the extensions enabled by the user (it will remember which of the extensions are currently enabled, won't disable extensions individually).
Similarly, run
gsettings set org.gnome.shell disable-user-extensions false
to enable the extensions.
pomsky
  • 70,557
18
In the recent versions of GNOME you can use the gnome-extensions command:
gnome-extensions enable <extension>
It's very useful.
gnome-extensions --help
Usage:
  gnome-extensions COMMAND [ARGS…]
Commands: help Print help version Print version enable Enable extension disable Disable extension reset Reset extension uninstall Uninstall extension list List extensions info Show extension info show Show extension info prefs Open extension preferences create Create extension pack Package extension install Install extension bundle
