I've been running 17.10, which is completely updated and current, and trying to upgrade to 18.04. My system should be perfectly capable of the new distribution, it's a quad-core AMD system running nVidia GTX 550 graphics. (I also run Windows 10 on it, with all the latest upgrades, and a copy of Win 7 just for old times' sake.)
I've tried it multiple times using command-line (both with and without the Developer option) and using the GUI method, and every time, the upgrade seems to complete flawlessly, but in the end, it reboots to a black screen with command-line only. It wants a login and password (which I've never used before, always login automatically), then tells me "Welcome to Ubuntu 18.04 LTS", and some further tidbits of info, then returns to a command prompt, still on an otherwise black screen.
Obviously, this is a problem, so I've wiped it and restored to the previous build (again). Anybody have any ideas as to what's going wrong? The full text of how my screen appears after upgrading follows:
Ubuntu 18.04 LTS BigBoy tty1 [NOTE:  BigBoy is my computer's name, no laughing]
BigBoy login:dave
Password:
Welcome to Ubuntu 18.04 LTS (GNU/Linux 4.15.0-20-generic x86_64)
* Documentation:  https://help.ubuntu.com
* Management:  https://landscape.canonical.com
* Support:  https:ubuntu.com/advantage
* Meltdown, Spectre and Ubuntu:  What are the attack vectors, how the fixes work,
and everything else you need to know -- https:ubu.one/u2know
0 packages can be updated
0 updates are security updates
You have packages from the Hardware Enablement Stack (HWE) installed that are going
out of support on 2016-08-04.
There is a graphics stack installed on this system.  An upgrade to a configuration
supported for the full lifetime of the LTS will become available on 2016-07-21 and
can be installed by running "update manager" in the Dash.
The programs included with the Ubuntu system are free software;  the exact
distribution terms for each program are described in the individual files in
/usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law.
dave@BigBoy:"$
djroff
  • 91
"startx" will indeed get you into the normal desktop environment from command-line purgatory. Once in, from the link Helene gave me, the problem was easy to fix. Apparently the upgrade process leaves display manager package "lightdm" in a broken state, and it has to be reinstalled (then selected in place of "gdm"). So it was just a matter of running "sudo apt-get install lightdm", once the system was up. Now everything boots normally.
djroff
  • 91
type startx in the terminal.
this should bring up the new environment.
Or it might give you lots of errors, that you can add to your question!
