64
This may be related to running 18.04 LTS as a virtual machine (Host is Win 2016 DC) but I can't figure it out how. I have tried every method of I know of to change the hostname but it always reverts to the hostname I entered when I built the machine on reboot. I have tried the following:
  1. hostnamectl set-hostname xxx.
  2. Editing hostname directly.
  3. Adding --static to hostnamectl.
  4. Editing hosts file and adding desired hostname.
  5. Searching drive for references to old hostname before reboot.
  6. A few other weird suggestions I found on the internet not worth mentioning.
I have no DNS for this server at this time.
Example:
XXXX@iwrxmail:~# hostnamectl
Static hostname: iwrxmail
Pretty hostname: Interwrx Ubuntu Mail Server
Transient hostname: ctl
     Icon name: computer-vm
       Chassis: vm
    Machine ID: 01ef0d836d2c4945b51a4fab8e506381
       Boot ID: e6608fe238d843f883cde52af7631a79
Virtualization: microsoft
Operating System: Ubuntu 18.04 LTS
        Kernel: Linux 4.15.0-20-generic
  Architecture: x86-64
XXXX@iwrxmail:~# hostnamectl set-hostname test
Static hostname: test
       Chassis: vm
root@iwrxmail:~# cat /etc/hostname
test
root@iwrxmail:~# cat /etc/hosts
127.0.0.1       localhost.localdomain   localhost
::1             localhost6.localdomain6 localhost6
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
However on reboot I get this again ....
       Chassis: vm
       Boot ID: 25a00676b22048eb8d43492c9de4f147
I had had this issue with the beta of 18.04, but I figured I would wait for the release copy. I also considered it might be a problem with the fact I had cloned the VMs, but this was a brand new version built from scratch with the just released distro.
What am I missing?
Thanks in advance.
7 Answers7
87
First edit /etc/cloud/cloud.cfg and set the parameter "preserve_hostname" from "false" to "true" and then edit /etc/hostname.
30
The hostname is being reset by cloud-init which can either be disabled as follows (after which you can set the hostname in the normal way e.g. using hostnamectl):
sudo touch /etc/cloud/cloud-init.disabled
Or you can use cloud-init and create/modify the user-data file (usually found at: /var/lib/cloud/seed/nocloud-net/user-data) so that the hostname: entry is set to the desired hostname (provided preserve_hostname: is not set). Firstly you'll need to clean the existing config (though, as mentioned in the comments, bear in mind this can reset various other settings if you have already set them):
sudo cloud-init clean
And then reinitialise cloud-init's config from the new/modified user-data file:
sudo cloud-init init
Then reboot. See the cloud-init docs for more details.
Pierz
  • 3,391
13
For the "lazy guys" like me, a copy-paste solution :)
sudo sed -i '/preserve_hostname: false/c\preserve_hostname: true' /etc/cloud/cloud.cfg && sudo hostnamectl set-hostname ReplaceThisWithTheHostnamePreferred
First command allows the new hostname to be remembered by the OS.
The second part (after the &&) will only run if the first part has finished successfully and will set the hostname to the desired value.
Regards! L
linux64kb
  • 1,189
1- Edit vi /etc/cloud/cloud.cfg and change
To
Save and exit.
2- Edit vi /etc/hostname and replace your new name in this file or you can do this step with bellow command.
hostnamectl set-hostname NEWNAME
Enjoy it :)
If you're not happy with leaving an older version somewhere, then simply open the file at /var/lib/cloud/seed/nocloud-net/user-data, and change your hostname at the line:
hostname: cm-lc-nc
Then run:
cloud-init clean
cloud-init init
It will then set /etc/hostname to the new value and will remain consistent across reboots. This will remove all traces of the previous hostname and in the event that preserve_hostname is either reset or ignored for some reason, you still won't lose your new hostname.
Levi H
  • 151
I had the same issue and found that, after removing the cloud packages, you can change your hostname.
apt remove cloud-init cloud-initramfs-copymods cloud-initramfs-dyn-netconf
Eliah Kagan
  • 119,640
Maddin
  • 19
For those arriving here on attempting to set the hostname on a read-only OS (such as a Live Ubuntu 20.04 USB drive with persistence) the following worked:
sudo crontab -e
The last line add a @reboot command as follows. Change myhostname to the name you want to use:
@reboot sudo hostnamectl set-hostname myhostname
Big thanks to @hs.chandra for the crontab trick
tresf
  • 1,072
