I suspect I have multiple Ubuntu installations on different partitions on my PC. But how do I find out about them? Which command to use?
Output of
sudo lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL
is
NAME FSTYPE SIZE MOUNTPOINT LABEL
sda 931.5G
├─sda1 ext4 660G /home/sda1_mountpoint 709G
├─sda2 1K
├─sda5 swap 7.7G [SWAP]
├─sda6 vfat 123.4G /data124G 132G
├─sda7 ext4 74.3G /data73G 80G
└─sda8 ext4 66.1G /
sdb ext4 931.5G
└─sdb1 ext4 931.5G /data1T data1T
sr0 1024M
and Output of
sudo parted -l
is
Model: ATA TOSHIBA DT01ACA1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 32.3kB 709GB 709GB primary ext4
2 709GB 1000GB 291GB extended
7 709GB 788GB 79.7GB logical ext4
6 788GB 921GB 132GB logical fat32
8 921GB 992GB 71.0GB logical ext4
5 992GB 1000GB 8266MB logical linux-swap(v1)
Model: ATA ST1000DM003-1ER1 (scsi)
Disk /dev/sdb: 1000GB
Disk Flags:
1 1049kB 1000GB 1000GB primary ext4
Background info - Some problem occurred when PC was not restarting. It was stuck in login loop and similar error to this was occuring. I did ctrl-alt-f1 . I found that user's home directory was missing i.e/ /home/ was empty! I did mkdir /home/user and copied an old backuped home directory there and restarted. It started fine. Later I mounted sda1 at /home/sda1_mountpoint. It gave missing superblock error. I had to do fsck, then it mounted. the missing home directory was found in sda1 .
So I think problem is with multiple installations. Also notice that none of the output of lsblk is /home.
EDIT After reading comments, I mounted sda1 to /home instead of /home/sda1_mountpoint
Output of etc/fstab is
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda8 during installation
UUID=10138724-bb55-4d41-b8f8-81fc42ec1a84 / ext4 errors=remount-ro 0 1
# swap was on /dev/sda5 during installation
UUID=7d10a86a-3139-45af-bfc5-3dbb26a3e767 none swap sw 0 0
# sda1
UUID=b50f72de-3b8b-4453-a743-cc37f06055a5 /home ext4 defaults 0 2
# sda6
UUID=DBA5-EDA5 /data124G vfat defaults 0 0
# sda7
UUID=01e6d118-230d-4f22-a528-3e7ff06aef39 /data73G ext4 defaults 0 0
# sdb1
UUID=a92ea8c4-c810-4c06-8586-285bed30ea3f /data1T ext4 defaults 0 0
Output of mount command is
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=12301796k,nr_inodes=3075449,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=2464372k,mode=755)
/dev/sda8 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=26,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
/dev/sdb1 on /data1T type ext4 (rw,relatime,data=ordered)
/dev/sda6 on /data124G type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/sda7 on /data73G type ext4 (rw,relatime,data=ordered)
/dev/sda1 on /home type ext4 (rw,relatime,data=ordered)
tmpfs on /run/user/108 type tmpfs (rw,nosuid,nodev,relatime,size=2464372k,mode=700,uid=108,gid=114)
gvfsd-fuse on /run/user/108/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=108,group_id=114)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=2464372k,mode=700,uid=1000,gid=1000)
