When trying to create a bootable USB drive for Windows 10 on Ubuntu using WoeUSB and the Windows 10 iso, I'm getting this error after it attempts to install it to my drive. Some of it installs to the drive, just not it all.
Installation failed!
Exit code: 256
Log:
WoeUSB v@@WOEUSB_VERSION@@
Wiping all existing partition table and filesystem signatures in /dev/sdb...
/dev/sdb: 2 bytes were erased at offset 0x000001fe (dos): 55 aa
/dev/sdb: calling ioctl to re-read partition table: Success
Ensure that /dev/sdb is really wiped...
Creating new partition table on /dev/sdb...
Creating target partition...
Making system realize that partition table has changed...
Wait 3 seconds for block device nodes to populate...
mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
mkfs.fat 3.0.28 (2015-05-16)
Mounting source filesystem...
Mounting target filesystem...
Applying workaround to prevent 64-bit systems with big primary memory from being unresponsive during copying files.
Copying files from source media...
cp: error reading './boot/en-us/bootsect.exe.mui': Input/output error
The command "cp "${source_file}" "${dest_file}"" failed with exit status "1", program is prematurely aborted
Resetting workaround to prevent 64-bit systems with big primary memory from being unresponsive during copying files.
/usr/bin/woeusb: line 1608: local: only_for_gui: readonly variable
Unmounting and removing '/media/woeusb_source_1524346346_31802'...
Unmounting and removing '/media/woeusb_target_1524346346_31802'...
You may now safely detach the target device
karel
  • 122,292
  • 133
  • 301
  • 332
Lewis.
