When installing the Epson Iscan driver for a V370 scanner 64 bit the following message appears and the installation fails N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'http://dl.google.com/linux/earth/deb stable InRelease' doesn't support architecture 'i386'
Asked
Active
Viewed 709 times
In terminal...
cd /etc/apt/sources.list.d # change directory
grep -i earth *.list # note the name of the found file
sudo pico google-earth-pro.list # edit the file using the above found filename
change:
deb http://dl.google.com/linux/earth/deb/ stable main
to:
deb [arch=amd64] http://dl.google.com/linux/earth/deb/ stable main
control+o # to save edits
return # to confirm the filename to save
control+x # to exit the editor
Update #1:
To solve the new errors that you detailed...
In terminal...
sudo rm -i /etc/apt/sources.list.d/google-earth-pro.list.save.1
sudo add-apt-repository ppa:webupd8team/y-ppa-manager
sudo apt-get update
sudo apt-get install y-ppa-manager
then run Y PPA Manager and click the Advanced icon, and select Try to import all missing GPG keys and Try to fix all GPG BADSIG errors.
heynnema
- 73,649
