I want to reinstall new Ubuntu because old corrupted. I have on this disk Windows so I m afraid that because this message Windowse erased. How to know during installation where it is windows on which disk sda? The following partitions are going to be formatted: Partition #9 of SCS1 (0,0,0) sda as ext4 Partition #10 of SCS1 (0,0,0) sda as swap
Asked
Active
Viewed 80 times
The system is indicating that it will remove partitions /dev/sda9, which is an ext4 partition and /dev/sda10, which is a swap partition.
Neither of those is a Windows Partitions.
You can run this command to see which partition has your Windows.
$ sudo fdisk -l
Windows is an ntfs partition.
This is an extract of the sudo fdisk -l from a computer in my shop:
$ sudo fdisk -l
[sudo] password for apollo:
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: D4900414-D1A2-4FC2-8DDD-3A93A9A57083
Device Start End Sectors Size Type
/dev/sda1 2048 739327 737280 360M EFI System
/dev/sda2 739328 1001471 262144 128M Microsoft reserved
/dev/sda3 1001472 785969987 784968516 374.3G Microsoft basic data
/dev/sda4 1924679680 1926369279 1689600 825M Windows recovery environment
/dev/sda5 1926369280 1953523711 27154432 13G Microsoft basic data
/dev/sda6 785971200 1899800575 1113829376 531.1G Linux filesystem
/dev/sda7 1899800576 1924679679 24879104 11.9G Linux swap
The Windows partition is /dev/sda3
L. D. James
- 25,444
