I have disks /dev/sda & /dev/sdb. The /dev/sdb is my internal backup drive.
The partitions on sdb were set up by dd-ing the corresponding sda partitions, so I presume that is why blkid shows the UUIDs on sdb are the same as the corresponding partitions on sda.
Though fstab says
/dev/sda3  /               ext4    errors=remount-ro 0       1
mount says
/dev/sdb3 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
This situation leaves me with no backup.
What to do?
@oldfred - Thank you for your help. However... I did tune2fs /dev/sda3 -U uuid... for all the /dev/sd* partitions, edited fstab to use the UUIDs (from blkid), rebooted, & still have the sdb3 backup of sda3 mounted after reboot.
[root:/home/rbf]# blkid | egrep -e 'sd.3'
/dev/sda3: UUID="c8c5991e-44f4-11e8-9876-4061864bb8d0" TYPE="ext4" PARTUUID="000d55c4-03"
/dev/sdb3: UUID="861f07b1-621f-459d-bdf1-0b4ef334b0f5" TYPE="ext4" PARTUUID="000d55c4-03"
[root:/home/rbf]# grep c8c5991e-44f4-11e8-9876-4061864bb8d0 /etc/fstab #sda3
UUID=c8c5991e-44f4-11e8-9876-4061864bb8d0 /               ext4    errors=remount-ro 0       1
[root:/home/rbf]# mount | egrep -e '/dev/sd.3'
On backup tools, I currently use the venerable cp command to back up, because it's old & I understand it (like myself).
mount /dev/sdb1 /mnt/sdb1
cp -pdfuR /boot/* /mnt/sdb1
etc. Do you see a problem with this (other than the growth in the target)?
