Am not able to copy files to usb or external hdd, it shows an error saying destination is read only, while in previous version i was succesfuly doing the same.Also i can easily paste files in windows os.
Asked
Active
Viewed 2,380 times
The destination drives are mounted, but for whatever reason, they've been mounted read-only. If you right-click on the mounted drive in nautilus (started as gksudo, like you did before), a dropdown menu appears. Go to Properties at the bottom, and then to the "Permissions" tab. Maybe it will let you change the permissions to "write" there and the problem will go away.
akgnitd
- 103
