I'm running Ubuntu 16.04. I have a few snaps installed. Looking in the system monitor it looks like there are several versions of each snap installed and that each version is consuming space on the hard drive.
Looking in my home folder it seems like there are just a few empty folders under the ~/snap folder.
But then it seems like the binaries for each snap are actually located under /snap.
So here are my three questions.
  1. What is the system monitor actually showing in terms of space used?
  2. What it ~/snap used for?
  3. What are the /dev/loopX files used for?
I know that there should be only one question in each post but in this case I think the questions are dependent on each other.
guntbert
  • 13,475
g3blv
  • 253
Snaps are squashfs images that are mounted into place, which is what you're seeing there. They are presented as disks which are 100% full, since each image is only as large as necessary to hold its data.
  1. What it ~/snap used for?
Snaps are (typically) confined, by default limited to a few areas when it comes to reading/writing. ~/snap holds snaps' user data (e.g. config files, etc.) since they can't by default write to $HOME.
  1. What are the /dev/loopX files used for?
Loop devices are what are used to make files accessible as a block device, such as when mounting the snap (squashfs) files. So when you install a snap, it's mounted, and a loop device is used. When a snap is updated, it keeps three revisions around (current and two old ones) in case you want to revert, so these old ones are using loop devices as well.
kyrofa
  • 7,502
