I would use:
sudo grep -rIlZ --exclude=${HISTFILE##*/} --exclude-dir={boot,dev,lib,media,mnt,proc,root,run,sys,/tmp,tmpfs,var} '/' -e 'MyWord' | xargs -0 cat > MyOutputFile
- Drop
sudo if not looking in system directories.
- Change (root directory)
'/' to current directory '.' or specific directory ie '/home/me/stuff'
- Remove
mnt to include Windows files mounted under mnt.
- Remove
lib to include Linux source files
- Excluding directories necessary for speed. See: `grep`ing all files for a string takes a long time
--exclude=${HISTFILE##*/} is necessary if you run the command a second time or if the search string MyWord has ever been used in a different command before. This prevents 5 thousand history lines ($HISTFILE) from being included.
-r recursive, I skip binary files, lZ outputs a zero byte after each file name instead of the usual newline. Null (zero byte) terminators necessary for perl -0, sort -z and xargs used to cat (print out) the file contents.
> MyOutputFile sends output to file instead of screen. Leave this off for output to screen.
Note: Missing from output is the file name, just the file content is listed.
