I ran the following commands to install java: sudo add-apt-repository ppa:webupd8team/java and sudo apt-get update. After that I ran sudo apt-get install oracle-java8-installer and got an error. Here's the error:
Connecting to download.oracle.com (download.oracle.com)|2.21.176.162|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2018-04-17 17:13:56 ERROR 404: Not Found.
download failed
Oracle JDK 8 is NOT installed.
dpkg: error processing package oracle-java8-installer (--configure):
subprocess installed post-installation script returned error exit status 1
Did I miss a step here? I searched for this error and the only thing I found was a question here in AskUbuntu instructing OP to run sudo apt-get purge oracle-java9-installer (I changed java9 to java8 since I'm trying to install java 8) then ran the command sudo apt-get install oracle-java8-installer again. It did not work.
