I need to install elasticsearch on Raspberry Pi 3. To do this I am following this link with below steps:
I first install java:
sudo apt-get update
sudo apt-get install default-jre
Running the above default-jre command showed some error so I ran these two commands:
sudo apt-get purge openjdk-8-jre-headless
sudo apt-get install openjdk-8-jre-headless
After this, followed below steps:
sudo mkdir /usr/share/elasticsearch
cd /usr/share/elasticsearch
wget https://packages.elastic.co/GPG-KEY-elasticsearch
sudo apt-get install elasticsearch
After this when I did sudo service elasticsearch status it always shows Active(exited).
How to install elasticsearch on Raspberry pi.?
Thanks
Error while installing default-jre
Error: missing server JVM at `/usr/lib/jvm/java-8-openjdk-
armhf/jre/lib/arm/server/libjvm.so'.
 Please install or use the JRE or JDK that contains these missing components.
 E: /etc/ca-certificates/update.d/jks-keystore exited with code 1.
 done.
 Setting up libatk-wrapper-java (0.33.3-13+deb9u1) ...
 Processing triggers for hicolor-icon-theme (0.15-1) ...
 dpkg: dependency problems prevent configuration of openjdk-8-jre-headless:armhf:
  openjdk-8-jre-headless:armhf depends on ca-certificates-java; however:
   Package ca-certificates-java is not configured yet.
dpkg: error processing package openjdk-8-jre-headless:armhf (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of openjdk-8-jre:armhf:
 openjdk-8-jre:armhf depends on openjdk-8-jre-headless (= 8u162-b12-1~deb9u1); however:
  Package openjdk-8-jre-headless:armhf is not configured yet.
dpkg: error processing package openjdk-8-jre:armhf (--configure):
Setting up libatk-wrapper-java-jni:armhf (0.33.3-13+deb9u1) ...
dpkg: dependency problems prevent configuration of default-jre-headless:
 default-jre-headless depends on openjdk-8-jre-headless; however:
dpkg: error processing package default-jre-headless (--configure):
dpkg: dependency problems prevent configuration of icedtea-netx:armhf:
icedtea-netx:armhf depends on openjdk-8-jre; however:
   Package openjdk-8-jre:armhf is not configured yet.
dpkg: error processing package icedtea-netx:armhf (--configure):
dpkg: dependency problems prevent configuration of icedtea-8-plugin:armhf:
  icedtea-8-plugin:armhf depends on openjdk-8-jre; however:
  icedtea-8-plugin:armhf depends on icedtea-netx (= 1.6.2-3.1); however:
  Package icedtea-netx:armhf is not configured yet.
dpkg: error processing package icedtea-8-plugin:armhf (--configure):
dpkg: dependency problems prevent configuration of default-jre:
 default-jre depends on default-jre-headless (= 2:1.8-58+b2); however:
  Package default-jre-headless is not configured yet.
 default-jre depends on openjdk-8-jre; however:
dpkg: error processing package default-jre (--configure):
dpkg: dependency problems prevent configuration of default-java-plugin:
 default-java-plugin depends on default-jre (= 2:1.8-58+b2); however:
  Package default-jre is not configured yet.
 default-java-plugin depends on icedtea-8-plugin; however:
  Package icedtea-8-plugin:armhf is not configured yet.
dpkg: error processing package default-java-plugin (--configure):
Processing triggers for libc-bin (2.24-11+deb9u3) ...
 openjdk-8-jre:armhf
 icedtea-netx:armhf
 default-jre
  default-java-plugin
S Andrew
  • 514
