How to enable Bluetooth in ubuntu (running on VM) ??
If you want the VM (using virtualbox) to access an internal bluetooth device then it is not possible. From Virtualbox
There is no progress and there will not be any progress in medium term. Bluetooth devices could work when connected via USB but we don't plan to support any internal bluetooth hardware so far. It's a lot of work with a questionable benefit
Otherwise if you are using a bluetooth USB then check this answer here
if you using vmware products this might help
ptetteh227
  • 2,044
