I have already asked a similar question, but my question was poorly worded. Although heynnema wrote a good answer, it is not exactly what I was expected. So here is a new version better worded.
┌─╼ [~/grive]
└────╼ sudo fdisk -l
[sudo] password for infinity:
Disk /dev/sda: 223.6 GiB, 240057409536 bytes, 468862128 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: CBF0E7EB-2677-4D68-B9B5-C9212D0CF17A
Device Start End Sectors Size Type
/dev/sda1 2048 1050623 1048576 512M EFI System
/dev/sda2 1050624 2549759 1499136 732M Linux filesystem
/dev/sda3 2549760 468860927 466311168 222.4G Linux filesystem
Disk /dev/sdb: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x96196249
Device Boot Start End Sectors Size Id Type
/dev/sdb1 2048 3907026943 3907024896 1.8T 7 HPFS/NTFS/exFAT
Disk /dev/sdc: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Disklabel type: dos
Disk identifier: 0x9619624a
/dev/sdc1 2048 3907026943 3907024896 1.8T 7 HPFS/NTFS/exFAT
Disk /dev/mapper/sda3_crypt: 222.4 GiB, 238749220864 bytes, 466307072 sectors
Disk /dev/mapper/ubuntu--vg-root: 154.4 GiB, 165767282688 bytes, 323764224 sectors
Disk /dev/mapper/ubuntu--vg-swap_1: 67.9 GiB, 72926363648 bytes, 142434304 sectors
Disk /dev/mapper/cryptswap1: 67.9 GiB, 72925839360 bytes, 142433280 sectors
┌─╼ [~/grive/Data_HFT/TnS]
└────╼ df -h
Filesystem Size Used Avail Use% Mounted on
udev 34G 0 34G 0% /dev
tmpfs 6.7G 11M 6.7G 1% /run
/dev/mapper/ubuntu--vg-root 151G 114G 30G 80% /
tmpfs 34G 27M 34G 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 34G 0 34G 0% /sys/fs/cgroup
/dev/sda2 705M 401M 253M 62% /boot
/dev/sda1 511M 4.7M 507M 1% /boot/efi
tmpfs 6.7G 16K 6.7G 1% /run/user/121
tmpfs 6.7G 44K 6.7G 1% /run/user/1000
/home/infinity/.Private 151G 114G 30G 80% /home/infinity
sudo fdisk -l made a list of all existing hard disks on my computer and df -h listed the hard disks use on my computer.
I wish to increase the memory of /home/infinity/.Private from 152G to 151G + 1.9T + 1.9 = 3.951T. I have two unused hard disks /dev/sdb and dev/sdc.
heynnema said in my previous question :
if your final goal was to make your /.Private larger by adding two 2TB disks to it, you should have said so earlier, 'cause that requires a different approach. What does making /.Private=3.95TB any different than using the disks mounted separately as you're doing now. If you still want to do that, I'd recommend using LVM disks... but that's a whole new question.
So how could I increase the global memory without losing information? I don't want to reinstall everything. If it is not possible to do it without reinstalling everything, how could I create another home?
I will explain to you what would be the purpose of that new space. I need to store around 300GB of data for machine learning purpose so that I could use it locally.
