I have Windows installed on my SSD (sdb), but its recovery and EFI partitions were created by default on my HDD (sda). I have another partition on the HDD for storing some files.
This is the information I got from Ubiquity with a general description of each partition (taken from the Windows partitioning tool):
sda1: Windows recovery partitionsda2: Windows EFI partitionsda3: NTFS general use partitionsdbis occupied by one NTFS Windows partition.
When I tried to install Ubuntu as usual, it didn't recognize Windows. I read how to set up Ubuntu's partitions manually, but it said I couldn't do it while keeping the other sda partitions.
Is there a way to do it without losing them?
EDIT: Output of fdisk -lu:
Disk /dev/loop0: 1.6 GiB, 1742868480 bytes, 3404040 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 82 MiB, 86011904 bytes, 167992 sectors
Disk /dev/loop2: 140 MiB, 146841600 bytes, 286800 sectors
Disk /dev/loop3: 1.6 MiB, 1691648 bytes, 3304 sectors
Disk /dev/loop4: 12.2 MiB, 12804096 bytes, 25008 sectors
Disk /dev/loop5: 21 MiB, 22003712 bytes, 42976 sectors
Disk /dev/loop6: 3.3 MiB, 3411968 bytes, 6664 sectors
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 9033DBB1-06EA-4D3F-80DE-DD7C2CBFA9B2
Device Start End Sectors Size Type
/dev/sda1 2048 1023999 1021952 499M Windows recovery environment
/dev/sda2 1024000 1228799 204800 100M EFI System
/dev/sda3 1259520 1783838719 1782579200 850G Microsoft basic data
Disk /dev/sdb: 111.8 GiB, 120034123776 bytes, 234441648 sectors
Disklabel type: gpt
Disk identifier: 1E74C216-5FA5-4648-BDC5-0EC101622203
/dev/sdb1 2048 234438655 234436608 111.8G Microsoft basic data
Disk /dev/sdc: 14.6 GiB, 15664676864 bytes, 30595072 sectors
Disklabel type: dos
Disk identifier: 0x01bf4af5
Device Boot Start End Sectors Size Id Type
/dev/sdc1 * 2048 30595071 30593024 14.6G c W95 FAT32 (LBA)
