Recently it's repeated constantly !! Network is Disabled shown in the network icon, my OS ubuntu 10.10 .
While I'm surfing on the NET after a while (may be 2 hours or may be a day) it disconnect and then can't connect to WiFi anymore till rebooting the machine !!.
I've searched and tried a lot of solutions but no useful one seems to solve the probelm :(
here is one in this forum it's same problem explained there but can't solve as mentioned !,also every thread/question related to the problem found here I tried but no hope .
"Rfkill list all" command shows:
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
even the Wireless button is switched on !
another command:
sudo ifconfig wlan0 up
SIOCSIFFLAGS: Operation not possible due to RF-kill
*"lshw" command:
*-network
   description: Ethernet interface
   product: RTL8111/8168B PCI Express Gigabit Ethernet controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:02:00.0
   logical name: eth0
   version: 01
   serial: 00:19:db:3d:d1:18
   width: 64 bits
   clock: 33MHz
   capabilities: bus_master cap_list rom ethernet physical
   configuration: broadcast=yes driver=r8169 driverversion=2.3LK-NAPI ip=192.168.1.102 latency=0 multicast=yes
   resources: irq:43 ioport:d800(size=256) memory:fe2ff000-fe2fffff memory:fe2c0000-fe2dffff
 *-network:0 DISABLED
       description: Wireless interface
       physical id: 1
       bus info: usb@1:6
       logical name: wlan0
       serial: 00:19:db:9d:d7:c3
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rt73usb driverversion=2.6.35-32-generic firmware=N/A multicast=yes wireless=IEEE 802.11bg
  *-network:1 DISABLED
       physical id: 2
       logical name: vboxnet0
       serial: 0a:00:27:00:00:00
       configuration: broadcast=yes multicast=yes
*of "lspci" command:
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 01)
please help....any suggestion will be appreciated .
wisdom
  • 303
if rfkill list shows 1 is hardblocked: did you try running
rfkill unblock 1
that works for me (but in my case i have to run rfkill unblock 0 and rfkill unblock 2, the first is my wireless switch, the second is the wifi switch)
cfstras
  • 143
I would file a bug on launchpad to report this intermittant failure.
In the interim, a few of potential things you can try.
Suggestion 1.
Boot using an earlier kernel - press SHIFT at boot time to display your Grub. Choose the previous versions option and select an older kernel
Suggestion 2.
Drop and start your lan connection via
ifconfig wlan0 down
ifconfig wlan0 up
Suggestion 3.
Force a restart of the network manager service
sudo service network-manager restart
Suggestion 4.
Unload and reload the kernel model and restart network manager:
sudo modprobe -r rt73usb
sudo modprobe rt73usb
fossfreedom
  • 174,526
Try when booting your computer:
 press f2? to get into bios
 press f9? to reset to default settings
press f10? to save settings
Check if you're still hard blocked.
[keys are for my laptop which isn't a dell you may need to check which are your own]
JSt
  • 477
For those who tried everything like me, including
rfkill list
suggested by @cfstras, you might try something ridiculously simple.
In my case rfkill list output was:
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: brcmwl-0: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
So I tried:
rfkill unblock 1
And this didn't help. After some googling I solved the problem just by pressing Fn+PrtScr which has the icon of wireless network. (I have Dell XPS 13 9343, but on your laptop this might be on some other button). HTH.
valk
  • 417
