Background
I am trying to make a very comprehensive backup of my Ubuntu system. I am running the following rsync command:
sudo rsync -aAEHSXxv --progress --delete --exclude={/home/sterlingbutters/Butters-Ubuntu-Backup/*, /home/*/.cache/*, /home/*/.local/share/Trash/*, /dev/*, /proc/*, /sys/*, /tmp/*, /mnt/*, /media/*, /lost+found} / /home/sterlingbutters/Butters-Ubuntu-Backup
Where the file structure should be pretty evident.
Problems
I get the following output regarding non-existent files/directories:
rsync: change_dir "/home/*/.cache" failed: No such file or directory (2) rsync: change_dir "/home/*/.local/share/Trash" failed: No such file or directory (2) rsync: link_stat "/dev/*," failed: No such file or directory (2) rsync: link_stat "/proc/*," failed: No such file or directory (2) rsync: link_stat "/sys/*," failed: No such file or directory (2) rsync: link_stat "/tmp/*," failed: No such file or directory (2) rsync: link_stat "/mnt/*," failed: No such file or directory (2) rsync: link_stat "/media/*," failed: No such file or directory (2) rsync: link_stat "/lost+found}" failed: No such file or directory (2) created directory /home/sterlingbutters/Butters-Ubuntu-Backup IO error encountered -- skipping file deletionDoes this mean that file doesn't exist on the source or the destination? (Because they clearly exist on the source)
Later on, I start to get a bunch of entries regarding the
.cachedirectory that I thought I excluded:... home/sterlingbutters/.cache/mozilla/firefox/90d4yr8z.default/cache2/entries/76A1426700B3173C5B976F65F04FA6CD01D90D15 ...I'm worried to "just see what happens" because if the directories aren't excluded correctly, I might end up with an infinite copy-loop since the destination directory is located at ~/.
My code almost exactly follows the patterns specified in the docs here (the only changes I've made I feel should still be acceptable): I also feel that my syntax follows that which I have found on other forum posts. Even if it didn't, wouldn't that pose a discrepancy between that and the docs in the link?
All help is appreciated - Thanks!
