I'm new to Ubuntu system. My server runs on Ubuntu 16.0.4 and kernel is 4.4.0-98-generic as shown by uname -r. I have successfully removed some of kernel images, but I'm experiencing the issue with the linux-image 4.4.0-119. The the output of dpkg -l linux-image* is
$ dpkg -l linux-image*
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                                 Version                 Architecture            Description
un  linux-image                         <none>                  <none>       (no description available)
un  linux-image-4.4.0-119-generic        <none>>                <none>       (no description available)
ii  linux-image-4.4.0-97-generic         4.4.0-97.120            amd64                   Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-98-generic         4.4.0-98.121            amd64                   Linux kernel image for version 4.4.0 on 64 bit x86 SMP
pU  linux-image-extra-4.4.0-119-generic  4.4.0-119.143           amd64                   Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-97-generic   4.4.0-97.120            amd64                   Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-98-generic   4.4.0-98.121            amd64                   Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
iU  linux-image-generic                  4.4.0.119.125           amd64                   Generic Linux kernel image
It seems to me that the linux-image-generic points to 4.4.119.125, but the server was booted with 4.4.0-98. This is where I got confused. If I want to remove the image 4.4.0-119, it gave me:
$ sudo dpkg --purge linux-image-extra-4.4.0-119-generic
dpkg: dependency problems prevent removal of linux-image-extra-4.4.0-119-generic:
 linux-image-generic depends on linux-image-extra-4.4.0-119-generic; however:
  Package linux-image-extra-4.4.0-119-generic is to be removed.
dpkg: error processing package linux-image-extra-4.4.0-119-generic (--purge):
 dependency problems - not removing
If I run
$ sudo apt-get remove  linux-image-4.4.0-119-generic
[sudo] passwor for ...
Reading package lists... Done
Building dependency tree
Package 'linux-image-4.4.0-119-generic' is not installed, so not removed
You might want to run 'apt-get -f install' to correct these:
 linux-image-extra-4.4.0-119-generic : Depends: linux-image-4.4.0-119-generic but it is not going to be installed
 linux-image-generic : Depends: linux-image-4.4.0-119-generic but it is not going to be installed
                       Recommends: thermald but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Adding -f didn't help. My question is, apparently 4.4.0.119 is not installed, but why is it in the output of dpkg -l linux-image* and how can I "remove" it? To make it even worse, I cannot run anything with apt-get. BTW, what does the first column of the above dpkg -l mean, for instance, un, ii, or pU? Any ideas whould be greatly appreciated. Thanks!
Collin
