I'm trying to install ubuntu-desktop on my ubuntu server, but every time I try to install I get depdendecy errors.
Every time I try to install the package it says it needs it just goes deeper and deeper. Ive tried clean, autoremove, clear cache, dist-upgrade, etc all of the recommendations online but none of them are working.
 ubuntu-desktop : Depends: checkbox-gui but it is not going to be installed
                  Recommends: python3-aptdaemon.pkcompat but it is not going to be installed
                  Recommends: unity-webapps-common but it is not going to be installed
Edit:
I'm logged in as the root user.
Command I was using to install: apt-get install ubuntu-desktop.
Commands I tried to fix it:
apt-get autoclean
apt-get clean
dpkg --configure -a
apt-get update
apt-get dist-upgrade
cclloyd
  • 361
I had the same problem after trying out KDE plasma and removing it without purging the ppa but the solution was to reconfigure lightdm with
sudo dpkg-reconfigure lightdm
Also, make sure you have installed lightdm and the ubuntu-unity-desktop
rabra
  • 26
