I am Unable to connect to Broadband Wifi in Ubuntu 16.04 in HP Notebook 15
while I am able to connect it with Window and Android mobile.
Below is info about my Wifi Driver and Hardware.
lspci
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 5500 (rev 09)
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
00:04.0 Signal processing controller: Intel Corporation Broadwell-U Processor Thermal Subsystem (rev 09)
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03)
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3)
00:1c.2 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #3 (rev e3)
00:1c.5 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #6 (rev e3)
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03)
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
00:1f.6 Signal processing controller: Intel Corporation Wildcat Point-LP Thermal Management Controller (rev 03)
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI
Express Fast Ethernet controller (rev 07)
0d:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe
Wireless Network Adapter
rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
uname -r
4.13.0-37-generic
nmcli dev wifi list
SSID MODE CHAN RATE SIGNAL BARS SECURITY
vivek_m Infra 1 54 Mbit/s 62 ▂▄▆_ WPA2
and sometime
nmcli dev wifi list
pg 1 Infra 6 54 Mbit/s 24 ▂___ WPA2
Currently I am unable to connect with pg1 and other pg2 is not showing in list while I am connected with android with pg2 at same time,
Sometime the pg2 connection is available in wifi list but not in command list, Please check screenshot, it is listed in wifi list in light shed and when I click on this It gave me an error:
(7) The access point /org/freedesktop/NetworkManager/AccessPoint/109 was
not in the scan list.
sudo lshw -c network
network
description: Ethernet interface
product: RTL810xE PCI Express Fast Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:07:00.0
logical name: enp7s0
version: 07
serial: 70:5a:0f:97:e8:cc
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:43 ioport:4000(size=256) memory:c5000000-c5000fff memory:c5100000-c5103fff
-network
description: Wireless interface
product: RTL8723BE PCIe Wireless Network Adapter
physical id: 0
bus info: pci@0000:0d:00.0
logical name: wlp13s0
version: 00
serial: 44:1c:a8:73:7d:25
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl8723be driverversion=4.13.0-37-generic firmware=N/A ip=192.168.43.204 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:16 ioport:3000(size=256) memory:c3000000-c3003fff
iwconfig
enp7s0 no wireless extensions.
lo no wireless extensions.
wlp13s0 IEEE 802.11 ESSID:"vivek_m"
Mode:Managed Frequency:2.412 GHz Access Point: CC:61:E5:42:7B:63
Bit Rate=72.2 Mb/s Tx-Power=20 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Power Management:on
Link Quality=52/70 Signal level=-58 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:1701 Missed beacon:0
Please let me know if something else needs here to answer and help me to connect to connect this Wifi.
Thanks.
