On my computer, I had multiple partitions and operating systems.
/dev/sda1 -> recovery
/dev/sda2 -> linux
/dev/sda3 -> swap
/dev/sda4 -> windows
I made an image backup of the linux partition:
pv < /dev/sda2 > linux-backup.img
Then, I formatted everything from the laptop.
How can I use this image in a new VirtualBox machine?
I am only interested in the linux partition and want to use it inside a virtual machine for some time. I tried converting the image:
VBoxManage convertfromraw --format VDI linux-backup.img linux.vdi
... but this gives me a whole disk containing the data (/dev/sda inside the VM), not a partition (I guess I would need the data inside a /dev/sda1). And the other problem is, that this is not bootable.
Does anyone have an idea?
UPDATE: updated the question to point out, that I will not use the partition simultaneously from the computer and from the VM! I just want to use it for some time in the VM.
I don't know how to do it using your .img file, but your goal is readily do-able using Clonezilla. Just take a Clonezilla backup of the partition, then boot your virtual machine using Clonezilla and restore the backup into it.
I actually just did this yesterday to test an 18.04 upgrade in a vm before doing it on the real machine.
The command VBoxManage convertfromraw is meant for disk images, not partitions images.
You need to create a new disk containing a partition from your image.
Disclaimer
The following instructions are adapted from my another answer and I haven’t tested them for an image yet.
Instructions
  1. Create a new VM with a new virtual hard drive with a sufficient capacity. Boot a live distro.
  2. Format the blank hard drive, create (at least) a single partition with equal or higher size than your image.
  3. Restore your image to the newly created partition, e.g.
    dd if=/media/shared/partition.img of=/dev/sdb1
  4. Optionally extend the restored filesystem to match the current partition size, e.g.
    resize2fs /dev/sdb1
  5. Restore GRUB using the chroot method.
  6. Edit configuration files if necessary (especially /etc/fstab, /etc/network/interfaces).
  7. Shut down the VM, detach the live distro media and boot your server clone.
References
Melebius
  • 11,750
