I'm trying to install the pecl oauth package with PHP 7.2 and don't know what I'm doing wrong. I ran this:
sudo pecl install oauth
and it seemed to work. It said this:
Build process completed successfully
Installing '/usr/lib/php/20151012/oauth.so'
install ok: channel://pecl.php.net/oauth-2.0.2
configuration option "php_ini" is not set to php.ini location
You should add "extension=oauth.so" to php.ini
I opened my php.ini file and tried all of these:
extension=oauth.so
extension=oauth
extension=/usr/lib/php/20151012/oauth.so
I restarted apache each time.
I ran php -m, phpinfo(), and get_loaded_extensions() each time and oauth doesn't show up.
I noticed this in the phpinfo():
extension_dir=/usr/lib/php/20170718
but pecl installed oauth into
Could that be the problem? If so, why would pecl install it into a different folder? Could I just move the oauth.so file into the 20170718 folder?
raphael75
  • 423
You may want to try this instead:
sudo apt-get update
sudo apt-get install php-oauth
sudo service apache2 restart
It worked well for me, running Ubuntu 18.04, PHP 7.2.5.
