So I am trying to create a music bot for TeamSpeak 3 and after some research I found that I have to create a so called virtual sink (which is basically a virtual output device) with pulsaudio and then feed the music into that sink. Every virtual sink you create comes with a monitor which acts as a virtual input device that records the output sink. Now the only thing left to do should be selecting the virtual sink monitor as capture device in TeamSpeak 3, problem is: the TeamSpeak 3 doesn't see the monitor, even though it is clearly listed as input device in the system settings.
Asked
Active
Viewed 688 times
So I found a solution to this problem: in pavucontrol there is a recording tab where you can set the input device for TS3 (or any application that records something) to anything you want, in my case the sink monitor.
Equiphract
- 11
