I use Ubuntu 18.04 on my Surface Pro 4. I have a problem with the sleep mode. When my Surface Pro goes to sleep, I can't wake it up with the keyboard, mouse or power button. I need to use hard shutdown. I think the device is waking up but the screen is staying black.
Asked
Active
Viewed 4,815 times
Upgrade the kernel to v4.16 With UKUU.
You should install Ubuntu Kernel Upgrade Utility (UKUU).
sudo apt-add-repository -y ppa:teejee2008/ppa
sudo apt-get update
sudo apt-get install ukuu
Run UKUU with this command:
sudo ukuu-gtk
In the UKUU GUI select Kernel 4.16 and install it. When the process finishes, you have to reboot.
Try it!
If after waking up, your Wifi is broken, you may tell to your system that, we want to explicitly unload on suspend and reload on the resume.
Create new dir /etc/pm/config.d
sudo mkdir /etc/pm/config.d
Create a new file in this dir
sudo touch config
Edit this file
sudo -H gedit /etc/pm/config.d/config
Add one line:
SUSPEND_MODULES="iwlwifi"
Save, close and reboot.
