I am not sure if the error I get is related to my apt-get setup if I do the following:
sudo apt-get update
sudo apt-get install openssh-server
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  ncurses-term openssh-client openssh-sftp-server ssh-import-id
Suggested packages:
  ssh-askpass libpam-ssh keychain monkeysphere rssh molly-guard
The following NEW packages will be installed:
  ncurses-term openssh-server openssh-sftp-server ssh-import-id
The following packages will be upgraded:
  openssh-client
1 upgraded, 4 newly installed, 0 to remove and 432 not upgraded.
Need to get 0 B/1.222 kB of archives.
After this operation, 5.133 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Preconfiguring packages ...
dpkg: warning: files list file for package 'i965-va-driver:amd64' missing; assuming package has no files currently installed
dpkg: unrecoverable fatal error, aborting:
 files list file for package 'libcrystalhd3:amd64' is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
Do you have an idea how to fix this?
Michael
To solve this issue, open terminal And run following commands:
sudo apt-get install --fix-missing
sudo dpkg --configure -a
That's it.
pa4080
  • 30,621
