New to ubuntu, new to WSL, I'm not even able to get ping to work. I've just installed ubuntu and it seems to be running fine. I've set proxy using
export http_proxy=http://mycompany.net:8080
Apt-get-upgrade seemed to work but with "0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded." Ping just locks up.
Also, as recommended, tried
sudo apt-get --print-uris install PROGRAM
which resulted in 'E: Unable to locate package PROGRAM'
Douglas
  • 103
Ping will not work without a route direct to the internet. That you have to indicates that you do not have such a route, but rather have to go trough a proxy. This is common in corporate environments.
As you get no error messages when you run apt update, this indicates that everything is fine.
vidarlo
  • 23,497
