[Solved now]
I've got a machine with 14.04 LTS x64.
Someone attempted to install a wrong package, libx32z1-dev:i386, and that seems to have buggered some things up. It removed a bunch of important packages for some reason (transcript below), and now when I run any apt-get install/remove command, I get something like this:
$ sudo apt-get install gcc-4.6
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 gcc-4.6 : Depends: binutils (>= 2.24) but it is not going to be installed
 libc6-dev-x32:i386 : Depends: libc6-dev-amd64:i386 (= 2.19-0ubuntu6.14) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
(gcc-4.6 was removed during the installation attempt)
I've found a couple similar questions (like How to recover from an apt-get problem), but the solutions don't work:
$ sudo apt-get remove libc6-amd64:i386 libc6-dev-amd64:i386
Package 'libc6-amd64:i386' is not installed, so not removed
Package 'libc6-dev-amd64:i386' is not installed, so not removed
Using dpkg directly doesn't help:
sudo dpkg --purge libc6-dev-amd64:i386
dpkg: warning: ignoring request to remove libc6-dev-amd64 which isn't installed
 sudo dpkg --purge libc6-amd64:i386
(Reading database ... 567282 files and directories currently installed.)
Removing libc6-amd64 (2.19-0ubuntu6.14) ...
Purging configuration files for libc6-amd64 (2.19-0ubuntu6.14) ...
Processing triggers for libc-bin (2.19-0ubuntu6.14) ...
If I do as APT suggests, then:
$ sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  at augeas-lenses binutils:i386 bridge-utils cpp-4.6 cpu-checker cryptsetup
  debugedit dh-apparmor ebtables fakeroot gcc-4.6-base ipxe-qemu jfsutils
  ldmtool ledit lib32asan0 lib32atomic1 lib32gcc1 lib32gomp1 lib32itm1
  lib32quadmath0 lib32stdc++6 lib64asan0:i386 lib64atomic1:i386
  lib64gcc-4.8-dev:i386 lib64gcc1:i386 lib64gomp1:i386 lib64itm1:i386
  lib64quadmath0:i386 libalgorithm-diff-perl libalgorithm-diff-xs-perl
  libalgorithm-merge-perl libasan0:i386 libatomic1:i386 libaugeas0
  libclang-common-3.5-dev libclang1-3.5 libcloog-isl4:i386 libconfig9
  libdevmapper-event1.02.1 libfakeroot libfontconfig1-dev libfreetype6-dev
  libgcc-4.8-dev:i386 libgd-gd2-perl libgfortran-4.8-dev libgmp10:i386
  libgomp1:i386 libhivex0 libice-dev libisl10:i386 libitm1:i386 libldm-1.0-0
  libllvm3.5 libltdl-dev libmail-sendmail-perl libmpc3:i386 libmpfr4:i386
  libnetcf1 libnetpbm10 libquadmath0:i386 librpmbuild3 librpmsign1 libsm-dev
  libstring-shellquote-perl libsys-hostname-long-perl libsys-virt-perl
  libvirt-bin libvirt0 libwin-hivex-perl libx32asan0:i386 libx32atomic1:i386
  libx32gcc-4.8-dev:i386 libx32gcc1:i386 libx32gomp1:i386 libx32itm1:i386
  libx32quadmath0:i386 libxft-dev libxml-xpath-perl libxrender-dev libxss-dev
  libxt-dev linux-image-4.4.0-38-generic linux-image-extra-4.4.0-38-generic
  llvm-3.5 llvm-3.5-dev llvm-3.5-runtime llvm-3.6 llvm-3.6-dev
  llvm-3.6-runtime lsb-security lvm2 msr-tools netpbm ocaml-base-nox pax
  po-debconf qemu-system-x86 rpm scrub seabios supermin watershed
  x11proto-render-dev x11proto-scrnsaver-dev zerofree zfs-fuse
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
Recommended packages:
  gcc-multilib:i386
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 27 not upgraded.
8 not fully installed or removed.
Need to get 0 B/3,872 kB of archives.
After this operation, 20.6 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Selecting previously unselected package libc6-amd64.
(Reading database ... 566979 files and directories currently installed.)
Preparing to unpack .../libc6-amd64_2.19-0ubuntu6.14_i386.deb ...
Unpacking libc6-amd64 (2.19-0ubuntu6.14) ...
Replaced by files in installed package libc6:amd64 (2.19-0ubuntu6.14) ...
Selecting previously unselected package libc6-dev-amd64.
Preparing to unpack .../libc6-dev-amd64_2.19-0ubuntu6.14_i386.deb ...
Unpacking libc6-dev-amd64 (2.19-0ubuntu6.14) ...
dpkg: error processing archive /var/cache/apt/archives/libc6-dev-amd64_2.19-0ubuntu6.14_i386.deb (--unpack):
 trying to overwrite '/usr/include/fpu_control.h', which is also in package libc6-dev-i386 2.19-0ubuntu6.14
The original installation attempt included these other steps, in addition to that big list of things that would be autoremoved:
  libc6-amd64:i386 libc6-dev:i386 libc6-dev-amd64:i386 libc6-dev-x32:i386
  libc6-x32:i386 libx32z1:i386 linux-libc-dev linux-libc-dev:i386
  zlib1g-dev:i386
Suggested packages:
  glibc-doc:i386 manpages-dev:i386
  gcc:i386 c-compiler:i386 gcc-multilib:i386
The following packages will be REMOVED:
  alien binutils build-essential camlp4 clang-3.5 clang-3.6 debhelper dkms
  dpkg-dev g++ g++-4.8 g++-4.8-multilib g++-multilib gcc gcc-4.6
  gcc-4.6-multilib gcc-4.8 gcc-4.8-multilib gcc-multilib gfortran gfortran-4.8
  hardening-includes lcov lib32gcc-4.8-dev lib32stdc++-4.8-dev libc6-dev-x32
  libc6-x32 libguestfs-dev libguestfs-perl libguestfs-tools libguestfs0
  libtool libx32asan0 libx32atomic1 libx32gcc-4.8-dev libx32gcc1 libx32gomp1
  libx32itm1 libx32quadmath0 libx32stdc++-4.8-dev libx32stdc++6 libx32z1
  libx32z1-dev lintian lsb-core network-manager-pptp
  network-manager-pptp-gnome ocaml-compiler-libs ocaml-interp ocaml-nox
  pptp-linux python-guestfs tcl-dev tcl8.6-dev tk-dev tk8.6-dev
  libc6-x32:i386 libx32z1:i386 libx32z1-dev:i386 linux-libc-dev:i386
  zlib1g-dev:i386
The following packages will be upgraded:
  linux-libc-dev
This question, dpkg error: "trying to overwrite file, which is also in...", has an answer that says to remove the conflicting package. Pattern matching the apt output, it looks like that is libc6-dev-i386 and libc6-dev-amd64.
But I don't seem to be able to remove it:
$ sudo apt-get remove libc6-dev-i386
 lib32ncurses5-dev : Depends: lib32c-dev
 lib32tinfo-dev : Depends: lib32c-dev
 lib32z1-dev : Depends: lib32c-dev
$ sudo dpkg --purge libc6-dev-i386
dpkg: dependency problems prevent removal of libc6-dev-i386:
 lib32ncurses5-dev depends on lib32c-dev; however:
  Package lib32c-dev is not installed.
  Package libc6-dev-i386 which provides lib32c-dev is to be removed.
 lib32z1-dev depends on lib32c-dev; however:
 lib32tinfo-dev depends on lib32c-dev; however:
dpkg: error processing package libc6-dev-i386 (--purge):
 dependency problems - not removing
 libc6-dev-i386
$ sudo apt-get remove libc6-dev-amd64
$ sudo dpkg --purge libc6-dev-amd64
Or I'm doing the wrong thing there too and don't see how to apply that solution.
Zanna
  • 72,312
EvanED
  • 271
This duplicated question provided most of an answer once I figured out what I was doing.
The conflicting packages were libc6-dev-i386 and libc6-dev-amd64. I tried removing the former with dpkg --purge libc6-dev-i386, which gave a list of three other packages that depended on it, shown in the messages above.
But removing those:
dpkg --purge lib32ncurses5-dev
dpkg --purge lib32tinfo-dev
dpkg --purge lib32z1-dev
(maybe in another order, again guided by their depedencies) then let me purge the conflicting package.
Then it was just a matter of grabbing the list of packages that were removed with the original apt-get install and installing them again via apt. Everything seems to be back to normal and working now.
EvanED
  • 271
