I'm using ubuntu 16.04 LTS.When I was running ambari-server,cloudera image in docker container and apache hadoop the system was not responding anymore.One fine day I observed that my total hard disk was filled with error log files under the path "/var/cache".
I have deleted all log files and freed my disk.I have checked running process using top command,suddenly I was able to find what is the cause for all these problems.cupsd is consuming 100% cpu all times.When I stop the cups service by running service cups stop command it stops the cups till the system is up and running.If I restart my system cupsd is again running and consuming total cpu.
I have searched in many forms to stop cups perminantly and ran following commands
echo "manual" > /etc/init/cups.override
servise cups stop
apt-get remove cups
echo manual > /etc/init/cups-browsed.override
systemctl disable cups.socket cups.path cups.service
systemctl kill --signal=SIGKILL cups.service.
All these commands are temporarily stopping cups.When I restart the system cups is again consuming total cpu.
I tried to remove all packages of cups by following commands.
apt-cache pkgnames cups
which lists all cups related packages. Then I removed all packages using
apt-get remove <package name>
Still cupsd is running and consuming total cpu.
Can anybody give a proper solution for this problem?
Also tell me is it to stop cupsd or not.
