I want to reinstall mysql in Ubuntu 16.04.
mysql-server is already the newest version (5.7.21-0ubuntu0.16.04.1).
You might want to run 'apt-get -f install' to correct these:
 mysql-server : Depends: mysql-server-5.7 but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
After this I wrote a code for removing mysql, but it's not being removed.
sudo apt-get purge mysql-server mysql-client mysql-common mysql-server-core-* mysql-client-core-*
Reading package lists... Done
Building dependency tree
Note, selecting 'mysql-server-core-5.1' for glob 'mysql-server-core-*'
Note, selecting 'mysql-server-core-5.5' for glob 'mysql-server-core-*'
Note, selecting 'mysql-server-core-5.6' for glob 'mysql-server-core-*'
Note, selecting 'mysql-server-core-5.7' for glob 'mysql-server-core-*'
Package 'mysql-server-core-5.6' is not installed, so not removed
Package 'mysql-server-core-5.5' is not installed, so not removed
Package 'mysql-server-core-5.1' is not installed, so not removed
Note, selecting 'mysql-client-core-5.5' for glob 'mysql-client-core-*'
Note, selecting 'mysql-client-core-5.6' for glob 'mysql-client-core-*'
Note, selecting 'mysql-client-core-5.7' for glob 'mysql-client-core-*'
Package 'mysql-client-core-5.5' is not installed, so not removed
Package 'mysql-client-core-5.6' is not installed, so not removed
Package 'mysql-client' is not installed, so not removed
 libmysqlclient20 : Depends: mysql-common (>= 5.5) but it is not going to be installed
 mariadb-common : Depends: mysql-common (>= 5.6.25) but it is not going to be installed
 mysql-client-5.7 : Depends: mysql-client-core-5.7 but it is not going to be installed
karel
  • 122,292
  • 133
  • 301
  • 332
You can try these steps:
  1. This removes mysql-server from your System.
    apt-get autoremove mysql-server
  2. Check if you still have mysql installed.
    mysql -V
  3. This installs mysql-server
    apt-get install mysql-server
If you are still having having issues start with
apt-get install -f
If it still does not work try:
dpkg-reconfigure mysql-server
David Foerster
  • 36,890
  • 56
  • 97
  • 151
