I'm trying to install Codelite on Ubuntu Artful (17.10). I've seen this problem is very common online but I haven't found a fix. Basically when I run sudo apt-get install codelite wxcrafter I get these unmet dependencies
Reading package lists... Done
Building dependency tree
codelite : Depends: libclang1-3.6 (>= 3.2) but it is not installable
Depends: libhunspell-1.3-0 (>= 1.3.3) but it is not installable
Depends: liblldb-3.6 but it is not installable
Recommends: lldb (>= 3.4) but it is not going to be installed
Recommends: nodejs but it is not going to be installed
Now I've tried to manually install Artful versions of the dependencies (such as libclang1-3.9) but the error remains there. I'm kind of a noob on these sort of things. Is there anyway to like manually install a dependency? (from like a downloaded file?) Or is there any sort of fix to this?
Thank you very much!
Edit: I don't think it's the same as the the question this is marked as duplicate: that's about clashing dependencies this is about missing ones!
