Hello need help to get my wifi chipset working.I have brcmsmac driver and i would like to have brcm80211 chipset up and running. I have tried everything but nothing helped?
  1. git://git.kernel.org/pub/scm/linux/kernel/git/dwmw2/linux-firmware.git
  2. Copy brcm/bcm43xx-0.fw and brcm/bcm43xx_hdr-0.fw to /lib/firmware/brcm (or wherever firmware is normally installed on your system).
    still got brcmsmac ??
then i tryed
  1. git clone git://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git git clone git://git.kernel.org/pub/scm/linux/kernel/git/dwmw2/linux-firmware.git
  2. cd ~/linux-next/drivers/staging/brcm80211 nano Makefile
the problem is that there is no brcm82011 folder?? do i follow cd ~/linux-next-a694cb1 like the link sad? i have Broadcom Corporation BCM4313 [14e4:4727]
fossfreedom
  • 174,526
There is no need of doing this much stuff. with brcmsmac your wifi should work fine but it only supports managed and monitor mode. There is no support for ad-hoc, access point and bridges yet. So a better option is use a "wl0" driver which supports managed and ad-hoc modes plus bridges and works much better. Procedure for installation:
  1. sudo apt-get install bcmwl-kernel-source
    or you can install it from synaptic manager also, make sure broadcom-sta-common, broadcom-sta-source, firmware-b43* are NOT INSTALLED.
  2. Even if you install the wl0 driver it won't load automatically as it is blacklisted by default. So make sure /etc/modprobe.d/blacklist-bcm43.conf file looks like this:
    \# Warning: This file is autogenerated by bcmwl. All changes to this file will be lost.
    blacklist b43
    blacklist b43legacy
    blacklist ssb
    \#blacklist bcm43xx
    \#blacklist brcm80211
    blacklist brcmsmac
    blacklist bcma
  3. If you wish you can copy above contents in your blacklist-bcm43.conf file.
  4. Hope this works, best of luck! and make sure you restart your pc.
zx485
  • 2,865
all I did is,
sudo apt-get install firmware-b43-installer
Avinash Raj
  • 80,446
