When I try to launch nautilus i got this error:
nautilus: error while loading shared libraries: libunity.so.6: cannot open shared object file: No such file or directory
I got the same with Marlin & Brasero.
I have tried this command:
sudo ln -s /usr/lib/libunity.so.9 /usr/lib/libunity.so.6
but it doesn't work at all.
Im going to cry... Please help me!
kOol
Are you on Oneiric? You could try
sudo apt-get install --reinstall libunity6
How to obtain this answer?
I first used
ldd /usr/bin/nautilus | grep unity
to check that it indeed needs libunity.so.6 on my machine as well. Then i ran
dpkg -S /usr/lib/libunity.so.6
to find out what package contains that file. It turns out that the package is libunity6. So it makes sense to try to reinstall it, which is what the above command does.
Timo Kluck
  • 9,173
