I'm looking to install Ubuntu 16.04 onto a new system with two GPU cards, however I can't get farther than the grub boot menu loaded onto the USB install key. Attempting to install (or try) Ubuntu results in multiple device timouts and events logged, and a hard restart required.
I believe I have ruled out hardware issues, using either card individually works fine, and I can install and use windows on the system with both cards installed just fine. If it helps the systems specs are:
AMD Rysen 5 1500X 8 Gbs RAM@ 2400 MHz Gigabyte GA-AB350 Gaming motherboard 2x AMD R9 390
I've attempted to install both Ubuntu 17.10 and the latest version of Mint with similar errors. If there is a better flavor of Linux for dual GPU system compatibility.
I'm not sure what else to try, and I don't have a ton of experience with Linux or Ubuntu (always looking for more), any suggestions are welcome. Also if this is a duplicate issue I apologize, please point me to the correct thread.
