I recently installed Ubuntu 16.04 LTS on my wife's laptop. Originally there was Win 7 on it and I simply wiped out everything and used the whole disk for Ubuntu. I followed the following guide to create partitions: How to use manual partitioning during installation?
After I filled the /home/user/... directory with some personal files I received the warning that /root was running out of space.
I checked the space available on the partitions and /home disappeared while /boot dramatically increased (During the installation, I assigned 500 MB to /boot and 230 GB to /home)
Filesystem Size Used Avail Use% Mounted on
udev 1,9G 0 1,9G 0% /dev
tmpfs 385M 6,2M 379M 2% /run
/dev/sda5 19G 7,6G 11G 43% /
tmpfs 1,9G 13M 1,9G 1% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 1,9G 0 1,9G 0% /sys/fs/cgroup
/dev/sda8 9,1G 22M 8,6G 1% /tmp
/dev/sda7 9,1G 983M 7,7G 12% /var
/dev/sda6 230G 250M 218G 1% /boot
/dev/sda9 185G 9,9G 166G 6% /opt
tmpfs 385M 60K 385M 1% /run/user/1000
What happened here? Or maybe.. what did I do wrong here? Thank you for your time.
Edit
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 465,8G 0 disk
├─sda9 8:9 0 187,6G 0 part /opt
├─sda7 8:7 0 9,3G 0 part /var
├─sda5 8:5 0 19,1G 0 part /
├─sda1 8:1 0 7,6G 0 part [SWAP]
├─sda8 8:8 0 9,3G 0 part /tmp
└─sda6 8:6 0 232,9G 0 part /boot
