I have installed windows 10 first and then ubuntu 16.04. after that ubuntu was showing in the boot. I saw some tutorial in online found that I have to update my grub or something. I followed the step and now ubuntu and windows both are there in boot. but the problem is it's not loading while I select the windows. while I select the windows blank screen comes up with default boot color and hand there for forever. what can I do? please help.
Do you mean default Ubuntu purple colour? First, you should check whether Windows will boot up independently of Ubuntu, ie on BIOS Boot Menu, not GRUB menu. It can be a little tricky if you haven't done this before.
To do that, start your computer and immediately select the appropriate function key and tap it quickly. I can't say which F number that is as it varies according to your computer model (on mine it's F12 key). Look it up in your manual or google for it. Sometimes it appears for a second at the bottom of the screen when you switch on. Assuming you already know or you find that key, and you have the BIOS boot menu up on screen, select Windows Boot Manager (or any similar sounding option name) and ENTER. If Windows fails to start up then you know it's a Windows boot problem, and perhaps you should look here, or try this and choose 'Repair your computer', or search or ask a question in this forum to resolve it. If Windows boots up correctly, then it's a GRUB issue. Let us know and we'll take it from there.
Paul Benson
  • 1,041
You may try boot-repair on Ubuntu http://ubuntuhandbook.org/index.php/2016/11/install-boot-repair-ppa-fix-boot-problems/
PawełG
  • 182
