I am getting this error when attempting to install software, or upgrade my system after a sudo-apt-get update. I have searched it, and many say it happens when your dist. is at its "end of life", but I am running Ubuntu 16.04 LTS. So my dist shouldnt be at its end of life.
sts... Done
Building dependency tree
The following additional packages will be installed:
  libexpat1-dev libpython3-dev libpython3.5-dev python-pip-whl python3-dev
  python3-setuptools python3-wheel python3.5-dev
Suggested packages:
  python-setuptools-doc
The following NEW packages will be installed:
  libexpat1-dev libpython3-dev libpython3.5-dev python-pip-whl python3-dev python3-pip
0 upgraded, 9 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,219 kB/39.2 MB of archives.
After this operation, 57.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Ign:1 http://ubuntu.uberglobalmirror.com/archive xenial-updates/universe i386 python-pip-whl all 8.1.1-2ubuntu0.4
Ign:2 http://ubuntu.uberglobalmirror.com/archive xenial-updates/universe i386 python3-pip all 8.1.1-2ubuntu0.4
Err:1 http://ubuntu.uberglobalmirror.com/archive xenial-updates/universe i386 python-pip-whl all 8.1.1-2ubuntu0.4
  403  Forbidden [IP: 202.124.241.168 80]
Err:2 http://ubuntu.uberglobalmirror.com/archive xenial-updates/universe i386 python3-pip all 8.1.1-2ubuntu0.4
E: Failed to fetch http://ubuntu.uberglobalmirror.com/archive/pool/universe/p/python-pip/python-pip-whl_8.1.1-2ubuntu0.4_all.deb  403  Forbidden [IP: 202.124.241.168 80]
E: Failed to fetch http://ubuntu.uberglobalmirror.com/archive/pool/universe/p/python-pip/python3-pip_8.1.1-2ubuntu0.4_all.deb  403  Forbidden [IP: 202.124.241.168 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Oppa
  • 181
My sources list was messed up. To fix everything, I replaced my currecnt "/etc//apt/sources.list" with the default found here https://gist.github.com/rohitrawat/60a04e6ebe4a9ec1203eac3a11d4afc1
Oppa
  • 181
A bad package repository can mess up your future installations. Go to /etc/apt/ folder and remove lists that are giving forbidden IP message. I was having node but unable to update it because of a messy repository jonathon or so. Removed it and flood gates for upgrade opened up.
