I have ubuntu 16.04 installed.. whenever I boot the system and try to run ubuntu, busy box pops up. I do a manual check ---fsck -yf /dev/sda12--- and then reboot.. now the ubuntu boots properly but then after few minutes i am not able to save/write anything on ubuntu(says the the disk is read only) nor can i open my other partitions which i was able to access few minutes ago. I again restart my system and the same busybox appears. The cycle goes on and on. What should i do.. is my hard drive completely corrupted?
Asked
Active
Viewed 5.4k times
Lets first check your file system for errors.
For Ubuntu 17.10 or older...
- boot to the GRUB menu
- choose Advanced Options
- choose Recovery mode
- choose Root access
- at the
#prompt, typesudo fsck -f / - repeat the
fsckcommand if there were errors - type
reboot
For Ubuntu 18.04 or newer... (or if the above steps don't work for you)...
- boot to a Ubuntu Live DVD/USB in “Try Ubuntu” mode
- open a
terminalwindow by pressing Ctrl+Alt+T - type
sudo fdisk -l - identify the /dev/sdXX device name for your "Linux Filesystem"
- type
sudo fsck -f /dev/sdXX, replacingsdXXwith the number you found earlier - repeat the
reboot
heynnema
- 73,649
first, run the command
blkid
then check the number of partitions
it will look like
/dev/numve2: UUID="kksgasjhgdjh36876" TYPE="ext4" PARTUUID="bdmdmd7-iuuyuy-89jlh" /dev/numve4: UUID="kksgasjhgdjh36876" TYPE="ext4" PARTUUID="bjjlo-iuuyuy-89jlh"
now just run the command for all partitions:
fsck /dev/numve2 -y
fsck /dev/numve4 -y
after done for all partition just run :
reboot
and choose ubuntu it will work!!
