I have tried everything. Looked into every single thread, nothing is working.
I tried pressing e in GRUB and adding "nomodeset"
I tried "nouveau.modeset=0"
Recovery mode doesn't help because when I open the root shell, the files are read-only.
I can't boot into tty
The screen is blank, nothing is responsive.
Zanna
  • 72,312
essana3
  1. Escape from black screen
    When you stuck on black screen, you can use Ctrl+Alt+F1 to select tty. Then you can type your username and password to login.
  2. edit /etc/default/grub
    Modify the line of GRUB_CMDLINE_LINUX_DEFAULT to
    GRUB_CMDLINE_LINUX_DEFAULT='pcie_port_pm=off acpi_backlight=none acpi_osi=Linux acpi_osi=! acpi_osi="Windows 2009"'
    Then reboot again. You should be able to see login page.
  3. Re-install nvidia driver (If step 1 & 2 cannot help)
    sudo add-apt-repository ppa:graphics-drivers/ppa
    sudo apt-get update
    sudo apt-get install nvidia-390 nvidia-settings
